Page 6 of 11
Posted: Wed Feb 25, 2009 8:29 pm
by framingsilly
OK Ken ,cool ,does that happen with the valves(#1 & #3) at the same time?Thanks for trying to help me
Posted: Wed Feb 25, 2009 8:30 pm
by framingsilly
never mind I'm a tard.
Posted: Sat Feb 28, 2009 8:13 am
Posted: Sat Feb 28, 2009 9:35 am
by Ken
Good stuff. It never hurts to have a refresher course.
Posted: Sat Feb 28, 2009 3:36 pm
by framingsilly
Pretty cool,nice and basic just what I need to sort things out .
Posted: Sat Feb 28, 2009 4:38 pm
Re read my explaination. The cylinder fires when the valves are closed. That{s what make the piston go down. You were there when you had your wife rotate the engine.
Posted: Sat Feb 28, 2009 7:33 pm
by framingsilly
OK found tdc for #1 .Valves closed on #1 . I checked to be sure by watching the #3 valves as the exhaust valve opens then just closes ,then when the intake just started to move I stopped and it was linned up with a notch.The notch it was linned up with was to the left of the notch I was using (about 2'' to the left)Anyways I readjusted the valves ,static timed,and put wires on accordingly.When I adjusted the valves the first time I was adjusting the #1 valves when it was on #3's turn( that was probably the boom I got?)That video 6volt posted helped.Now that I think wires etc. are correct ,went to fire it up and ZIP.Almost started but no Dice.Any idearz.
Posted: Sat Feb 28, 2009 9:11 pm
by Ken
Pull out all the spark plugs and make sure they are properly gapped and not fouled. Install new ones if any doubt about condition.
Make sure you are getting enough fuel. Try some starting fuid if necessary.
Keep a fire extinguisher handy.
Posted: Sat Feb 28, 2009 9:17 pm
Along with what Ken said, if you're running points, you're going to have to re-check the point gap.
Posted: Sat Feb 28, 2009 10:00 pm
by framingsilly
New points,new plugs(gapped correct).I read starting fluid isnt good to use.Dont know if that s true or not.Just a little frustrating.But I am learning alot more than if it would have started right up.Battery is dead from cranking ,is it cool to just use jumper cables or just pull the battery and charge it.
