A restoration like that is a lot of work as you know
Bet you won't attempt that again...
Nice job. Gotta feel good to have it driveable.
Six Volt wrote:
19mm to remove top and bottom rgb bolts.If you're not lazy like me, remove the tire so you don't make a mess.
toolbox wrote:That is a 17mm allen for the drain and fill plugs. What size was the hammer you used to get a 19mm to work?
Or the metric equivilant of Americcan Standard (NPT)WideFive wrote:I bet they are (NPT) pipe thread plugs... The hex head is technically 3/4" not 19mm.
