And did you go 70
63'Kooper271 wrote:What year is your bus, Rick?
Yes, got it up to 75. Carbs still need more tuning and playing around with.wwebner wrote:And did you go 70
Do I get to say I helped you guys pick that out?
Looks Great Rick!
Looks Great Rick!
I'm surprised the needles stayed on that tree with all that horsepower pushing it down the road.
It was a long 1/4 mile drive home! LolKen wrote:I'm surprised the needles stayed on that tree with all that horsepower pushing it down the road.![]()
Started up on some spring maintenance. Pulled the widefive front beam out. As much as I love how the bus sits, its just a little to low... So Widefive refurbed my stock beam and its going back in. Pulled the lowered beam out this afternoon. After that, the next project is to pull the motor, remove the tin, and retorque the heads and do some carb tuning.
Is re torquing the heads a maintenance thing after an engine rebuild?
Awesome Rick!
How low is too low?
How low is too low?
Retorquing heads is a myth. There should be no reason to do this unless there is some other problem. Bus looks good on it's side
