verboten1 wrote:
chuckspence wrote:if orange is what you're hooked on check out VW tropical orange (code LA2Y) 2 year only metallic orange used on golfs/GTI's
I do like that, but it's more than I plan on spending at the moment. I actually like the Fahrenheit orange a bit better, but again, actual mixed paint is out of my range. Trying for a stock ish color combo of orange and white, something I can spray and fix easily, because I'm ok, but not great. I've found that 2 stage paint is not my forte.
http://www.tcpglobal.com/
If you are on a budget. Can mix any color. Have lacquer and acrylic urethane
verboten1
Post by verboten1 »
More good stuff!
verboten1
Post by verboten1 »
More parts! Just kampers metal since I'm not super rich. Much better than the klokkerholm crap
I'm thinking this will be a very nice van when all is said and done. Look forward to following the progress
verboten1
Post by verboten1 »
Thank you! I'm waiting for some tools and I'm really trying to line up a tank for my welder.
I'm going to start digging into that slider track soon though!
verboten1
Post by verboten1 »
Spent the day on the roof with my dad, but I cut out the crappy gas pedal mount area, and I was able to weld in a new section. My welding sucked, you don't get to see it!
Is your welder set up for gas or flux core? Start in the places that are not seen very easily so when u get to the visible work you will be more comfortable with your machine and the materials being welded. You will have a much better product in the end..:-)
verboten1
Post by verboten1 »
That's why I chose this as my welding project on the bus. I'm pretty good at welding once I get into the groove, I'm just not there yet. I am using flux for right now. My cylinder is expired, having issues with my supplier getting a new tank/ certified
Did u reverse the polarity on your machine when u put flux core in it?
I'm a fan of gas shielded mig but I had the same problem with my tank and was forced to use flux core..
