Exactly!wwebner wrote:That's his "Anti Theft" systemDual Port wrote:Oh, did I forget to mention that you also adjusted the points in that engine so wide that they would not close?
1957 Oval
Re: 1957 Oval
Re: 1957 Oval
Got the bug back from Bill's this week. Unbelievable job by Bill on the interior! Also thanks to Lurch for helping with the glass install.
I'll get some pics up in the next couple days, but for now I'm researching upgrading the front brakes.
Since I know next to nothing (and readily admit it) I thought I'd ask for some input.
I've seen front disc replacement kits for early (stock height, 15" wheels, link pin front end and wide 5 bolt pattern) bugs go from $300 http://www.mamotorworkstv.com/vw/product/322467/ to $1300 http://www.mamotorworkstv.com/vw/produc ... kit-front/. I've also seen some middle of the road priced kits that have a 7/8" offset on each wheel. http://www.cbperformance.com/ProductDet ... tCode=4202 With any of them, add in the replacement MC and resevoir and probably some replacement brake lines, seals and front bearings and it can get a little pricey. But my kid will probably want to drive this and today's younger generation has no concept of "proactive slow down in advance for shoe braking" so I'm going to bite the bullet.
So, the $300 kit scares me because there has to be a quality difference bwtween the higher end packages and even cheaper $239 kits
like these http://www2.cip1.com/ProductDetails.asp ... C10%2D4120. The $1300 kit is probably great, but can I get away with someting a little cheaper that will still give me an acceptable level of safety? What's the difference between 5/130 and 5/205 set ups? Is one more correct for an early stock beetle? Is the offset a real problem with stock 15" 165 radials?
Appreciate your knowledgable input.
Re: 1957 Oval
Re: 1957 Oval
Why do you need to upgrade the brakes? Install a dual master and call it good.
Re: 1957 Oval
Re: 1957 Oval
toolbox wrote:Why do you need to upgrade the brakes? Install a dual master and call it good.
Have you driven an early Beetle? It's not a question of hydraulics, they need 3x the friction surface that they have. It's like driving with wet shoes when they're dry.
I'm with 6V, put bigger front brakes on it if the kid's driving, and bigger rears wouldn't be a bad idea either (I have a hunch that early T3 bolt on, I put them on my Ghia [4 lug] for a noticeable difference even with discs). Too bad it's KP and Ghias didn't have disc/KP.....
Re: 1957 Oval
Yea, I'm not a carpenter so don't be playing that "tape measure card" on me!WideFive wrote:5x205 is early VW.Six Volt wrote:What's the difference between 5/130 and 5/205 set ups? Is one more correct for an early stock beetle?
5x130 is later Poorsche bolt pattern
You don't own a Poorsche.
I know you aren't too much of a dumbas to use one of these...Six Volt wrote:Is the offset a real problem with stock 15" 165 radials?
Well, don't let me down anyhow
Come on man, WWWFD?
Re: 1957 Oval
Re: 1957 Oval
WideFive wrote:I'd get out a tape measure and make sure I had 7/8" clearance.Six Volt wrote:Come on man, WWWFD?
Got it Bro!
But I'm not up on "rocker" surgery!WideFive wrote:This isn't rocker surgery...
Re: 1957 Oval
Dual Port wrote:toolbox wrote:Why do you need to upgrade the brakes? Install a dual master and call it good.
Run early Type III in the rear and 66 Type I in the front. Get some high friction linings installed on the shoe tables, have them arced to the drums and all should be good.
Sean,
you need to get Fergus a late 60's full sized car with manual drums all around so he can learn anticipation braking.
Users browsing this forum: toolbox and 0 guests
