Pat and I ghetto rigged a Gasket because I have a exhaust leak so could that of been the reason why I didn't pass the E-check?
'88 Vanagon
Nab21094
'88 Vanagon
I just got a Vanagon and I'm trying to get it to pass an E-check which I failed..
Re: '88 Vanagon
Just move to one of the 86 counties in Ohio that don't have E-check!
Those that are easily offended and can't understand sarcasm shouldn't try to talk to me!!!
71 Westy
73 Bug (the wife's)
71 Westy
73 Bug (the wife's)
Re: '88 Vanagon
What portion did it fail?
Too many variables without a better understanding of why it did not pass.
framingsilly
Re: '88 Vanagon
We got the van back. Nick drove it a couple days. Hose ruptured, he lost coolant. Heads got warpted, things got melted. That's that. It is getting fixed again now. If anyone wants to take this thing off my hands let me know. Im just fed up rite now. Vanagons are very expensive to fix and im sticking with air cooled. Just blowing off a little steam and you will probably see him driving it around to some of the events this summer unless another one of the THOUSAND cooling componets goes bad and I end up scraping that PILE! Ok now that that's off my chest, see you guys thursday. Its ST. PATTYS day and if anyone needs a ride to or from Basil's I will be happy to give you a lift. Peace.
framingsilly
Re: '88 Vanagon
Another hose ruptured. No damage this time. I caught it before very much coolant came out. Waterboxes RULE! !!!!!
framingsilly
Re: '88 Vanagon
Just replaced coolant hoses in the engine bay that my engine builder neglected to replace. ( All of them ! )Ok that's squared away. Im going to do the ATF fluid tomorrow. I ordered the filter from the zone. What would you experienced folks suggest as far as fluid goes? Weight etc. Transmision doesn't shift from first to second when its cold. ( automatic trans. 220,000 miles ) when its warm everything works well. I've heard these are sensitive to the amount and cleanliness of the ATF fluid. Thank you for any info.
Re: '88 Vanagon
Here is what the job books at -Listed as a B skill level and pays 0.8 hours for the trans pan and filter R&R.
CAPACITY, Initial Refill*:
All models 3.0 Liters (3.2 Qt) Does not include final drive
*Add specified quantity. With engine at operating temperature, shift transmission through all gears.
With the engine running, check the fluid level in PARK and add fluid as needed.
TYPE ATF (DEXRON-II (R) Automatic Transmission Fluid)
Final Drive
Group: 37
Number: 93-11
Date: June 15, 1993
Subject:
Synthetic oil for automatic transmission final drive
Model(s):
All vehicles with automatic transmissions 010, 096,
087, 089, 090, 098
All m.y.
Effective immediately, SAE 75W/90 synthetic oil must be used as replacement oil for final drive units of automatic transmissions 010, 087, 089, 090, 096 and 098.
If the final drive contains standard oil, drain the oil completely and refill with synthetic oil. Do not mix synthetic oil with standard gear oil.
Synthetic oil is available as follows:
^ 1.0 L size: Part No. G 052 145 A2
CAUTION
Use ONLY the synthetic oil specified above for Volkswagen final drive units.
Final Drive
Group: 37
Number: 93-11
Date: June 15, 1993
Subject:
Model(s):
087, 089, 090, 098
All m.y.
CAUTION
